Hi there, could really use some help, typing fast so excuse any mistakes. Basically i was using my pc all day and it was a pretty hot day then during a game the pc just shut off, after unplugging replugging etc it wouldn't turn back on. to make a long story short i sent back the PSU and got a new one. Ive had this pc for a while with no problems keep in mind. I got the pc back hooked up everything and tried to turn it on - again nothing. I took out the gtx 970 and voilaa, it turned on everything was good all fans spinning etc and the pc works with cpu on board graphics everything works. I plug the GPU back into the pci slot and the pc still stays on etc and the gnu fans start spinning like normal, I plug the right hand side pci-e cable into the the 6 pin slot on the right everything still works fine gpu fans spinning, if i plug in the DVI cable to the gpu the monitor says please power down and connect PCI - cables. So i plug in the left hand side pci-e cable the 8 pin and as soon as the metal touches the pin thing , pc instantly turns off, i pull it out pc comes back on and i can repeat this. Even with the gpu not plugged into the slot and i just put the 8 pin connector in pc does and doesn't turn on. I have no other pc i can do any tests on etc and theirs no visible damage to GPU any ideas ? is the gpu done ? or? Thank you.
