[SOLVED] PC won't turn on ?
Jan 23, 2022
When I press the power button on my case the computer does not turn on, no fan spin, no light on the case.
But my headphones light turns on. I already tried resetting the CMOS battery and cleaning the RAM sticks and replacing them
Specs
Amd fx6300
Gigabyte ga-78lmt usb3 (motherboard)
2x 4gb ddr3 ram
GTX 660
AXT switching power supply (400W)
Whats the solution?
Phillip Corcoran
Your PSU full name is CiT 400HE.
CiT power supplies are cheap & poor quality, in reality it's probably not even 400 watts.
You need a new power supply, one that's much better quality. That one you bought was a bad choice. Never buy a cheap PSU. They are cheap for a reason.
Keep your fingers crossed that it hasn't damaged any components when it failed.
Phillip Corcoran
