I have had my pc for almost 5 years always ran good and got gifted a set of ram sticks 2x8gb from corsair vengance RGB. i already had 2 sticks of corsair vengance RBG and they also ran at the same speeds. Once they were in my pc my pc started acting wierd, from powercycling to not starting up and not posting i knew something with my ram was wrong. my pc would only work with 1 stick of ram so i thought it was a ram problem. checked every stick in all slots and they all worked in every slot when i was only using 1 stick when i would put in a second,third or fourth in it wouldnt work. so i have replaced my motherboard thinking a slot was broken, still having the same issue, also i just upgraded cpu so the issue can't be there since ive tried 3 cpu's with no help. also i tried new ram but also did not work.... ofcource reset cmos and bios is all up to date.
PC Specs:
Asrock B550M steel legend
AMD 5600X
4x 8gb corsair vengance RGB
GTX 1660ti
PC Specs:
AMD 5600X
GTX 1660ti
