PC works fine without graphics card,but with graphics card installed pc won't boot
chillicress
Commendable
Nov 2, 2016
4
I just bought a new pc that has everything installed except the graphics card, and it works fine.once i put the graphics card in, the pc won't boot , and there is a blank screen.Once i remove the graphics card, the system works fine again. Do you think that the graphics card is the problem or the pc itself? I am quite sure the psu has enough wattage.
Hello!
Most likely the GPU is to blame.
If you bought the PC pre-made then contact the company that made it and they will replace it for you on warranty.
If you built the system yourself then please contact the manufacturer of the graphics card and they will be able to replace the card for you so either way everything will be alright :)
I hope this helps!
GameFreak01048
694
Hello!
I hope this helps!
