PCI-E 6+2 Pin Cable for Nvidia GTX 1080 Turbo Cooling
tommunistzhangster
5
Hi!
So I've been experience difficulties with my graphics card, power supply, and PCIE 6+2 Pin cable. I really don't know much about cables, so I was wondering which I side I needed to plug into my power supply and graphics card.
One side is 8-pin, and the other side is 6+2 pin.
Here's my graphics card:
https://www.amazon.com/Gigabyte-GeForce-GV-N1080TTOC-8GD-Video-Graphics/dp/B01MEEAE9J/ref=sr_1_fkmr0_2?ie=UTF8&qid=1516675033&sr=8-2-fkmr0&keywords=nvidia+gtx+1080+gigabyte
Here's my power supply:
https://www.amazon.com/Corsair-Bronze-Certified-Modular-CP-9020099-NA/dp/B00OVCJKWC/ref=sr_1_4?s=electronics&ie=UTF8&qid=1516675159&sr=1-4&keywords=corsair+850+watt+power+supply
If y'all need anymore information, please tell me so.
Thanks!
Assuming that PSU comes with another PCI-e cable, did you try it? I'm wondering if the cable you are using is no good.
Can you test the GPU in another system?
Try plugging the PCI-e cable into another slot on the PSU?
It's not a PSU issue right? It worked with previous card for example?
I'm doing exactly what you are telling me to do, but I keep getting a message that reads "Please power down and connect the pcie power cables" even though I'm fairly sure I plugged them in.
Do you know how I'm screwing up?
I connected them properly, but it still shows the same message. Could it be my cable that's the problem?
Possibly. I have seen wire ends loose in the connector more than once. A careful inspection may be in order.
You know, I just checked amazon and apparently the cord I bought is only compatible with Silverstone PSUs, so I made a big mistake (I have a corsair power supply). Turns out that the cord is the problem.
Thanks anyways though!
