I need help with where and how I should plug in my pci-e cables into the GPU and "JPWR2" on my motherboard. I have just moved all of my PC components into a new case and I am stumped on this last part. I have forgotten where I plugged the pci-e cables from last time. The cables don't seem to fit correctly into either the GPU or the "JPWR2."
My mobo is an MSI 970 Gaming and my GPU is an AMD Radeon r9-390.
Here are the images of the pcie- cables I have to work with and where I need them to plug into:
pci-e cable(x2 of these): https://imgur.com/a/smjcD
GPU: https://imgur.com/a/hUdgQ
JPWR2 on mobo: https://imgur.com/a/rc51G
Reminder: I am using the same pci-e cables from before and they should work somehow. The plugged in fine before I moved my PC parts into the new case.
