PCI-E Power Cable
aeleos
6
Does anyone know where I could buy a PCI-E Cable that outputs to 1x 6 pin and 1x 8pin for powering a graphics card? I lost mine and need one to get my computer up and running. Trying to get it to work with molex adaptors would not work since I have only room for one more PCI-E cable on my PSU and need 4 more molex connectors to power it. Thanks
I need something that is like that, but has a female input that plugs into a power supply. Or a female to female connector to go with it. Thanks for finding that.
What power supply are you using? Sounds like you have a modular power supply, and lost one of the cables.
Something like that, you may have to contact the manufacturer. There are some aftermarket replacement cables for modular power supplies, but they are not quite universal. Aftermarket suppliers tend to support the more popular power supplies.
Casey
