So a couple of years ago, I was upgrading my mobo, CPU and RAM to what I have now from the MSI Z97 Gaming 5 motherboard. The GPU retention mechanism was very stiff and to make a long story short, I damaged the PCI-E slot on the mobo. I'm wondering if it's safe to use still if you used the 2nd PCI-E slot. I know the 2nd slot is an 8x and not a 16x, so you'll lose a few frames, but I'm selling my old stuff, but I'm unsure of selling the mobo. I'm selling to a friend who is aware of the issue. Does anyone think it's safe to even plug this in and try to use it? Personally, I don't think it's a good idea.
Here are some pics of the mobo and you'll see it's pulled up from the mobo itself. There are a couple of contacts/pins pulled away from the plastic shroud it's in. It could likely be repaired if you had the tools, maybe a soldering iron, but I can't fix this type of problem. Judging by the pictures, is it safe to use, or should I not risk it? If you avoid using the slot itself, is it safe or not? It's too bad, it was a great and beautiful motherboard! I was going to sell an MSI GTX 1070 Gaming 8G, 32 GB of G.Skill DDR3 RAM, i7 4790k CPU, and the mobo (if it's safe), all for $200. Am I being fair as well with the price? I think so, regarding what I'm selling. Everything else works beautifully. If I don't include the board, I'll sell it for $150 and still throw the board in, but won't recommend using it. It could be fine and then again, it could fry every component on it. l like to be overly cautious. Thanks in advance!
Link to pics of the mobo
