PCI Express Power Connectors and changing graphics card, I'm confused
firefalcon124
13
Hello,
I have a question about upgrading my current Amd Radeon HD 6850X2 to a GTX 770.
I've read on the spec page for the GTX 770 that it requires an 8+6 pin PCI Express Power Connector, but I'm not sure exactly what that means.
From what I can see inside my rig, my current Card is connected to my PSU via a single 6 pin PCI Express Power Connector, which itself seems to be converted from two 8 pin PCI Express Power Connectors (I'm not sure though, it's kinda hard to tell).
Given I need 8 pin and 6 pin PCIe Power Connectors for a GTX 770, what do I need to do/get to install it ? Will an adaptor come with the graphics card ? Or do I need to change my PSU ?
Cheers,
Owen.
Edit: As far as power goes, I largely suspect I'm fine, as a GTX 770 uses ~30W less than my current HD 6850X2.
Either on of these will work for an 8-pin
Either one of these will work for a 6-pin
So I will need to change my PSU ? I only have two 8 pin cables, and nothing to fit a 6 pin connector...
