DarKAzNKiD
52
Im plannin on gettin a rad 9800 pro...and since it doesnt take up a pci slot i could either get it a vga fan or a pci slot fan...will a simple 10 dollar pci slot fan be enough to cool the card down? Thanks.
SHARKMEAT
122
Heck why get a fan at all unless you plan on over-clocking the card.It runs fine with stock set-up out of the box.If overclocking is the case 10 bucks will be a waste of money,If you worried about heat why not get the ultra 256 and be done with it (memory heatsinks and all),besides you will have better warranty.
TREAD SLOWLY IN DANGEROUS WATERS
Crashman
Polypheme
Former Staff
I think it's a good idea to add extra cooling to the card. The stock cooling solution is most likely...barely adequate. A slot cooler would probably add just a little insureance against overheating it.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
