PCI fan placement
oobymach
287
88
I used to use a similar fan, put it above the back of the vid card with the fan facing the back of the card, it won't help much, better to have a fan blowing on the back of the card (you can mod that fan to do the job if your case has room).
Gam3r01
I would place it above the card, it is an exhaust fan, and most GPUs intake from the bottom so it should blow towards that fan.
Honestly, I dont see it helping much. I would recommend a new case if you can.
oobymach
287
88
dinosaur2910
26
so i should place it facing my gpu fan?
