Hello guys,
I got 3 PCs in my network, the specs for the three PCs are given below. Anyway, I've recently come across 3 used GbE NICs (Intel X550 T2) for free cause my company is scrapping one of their servers, so I and was planning to install them on my 3 PCs and set up a Peer-to-Peer 10GbE connection for transferring files between the 3 PCs. As each cards have 2 ports, I can hook up PC1-PC2, PC2-PC3, and PC3-PC1. And lastly, the NIC uses PCiE v3.0 (8.0 GT/s) x4 connection.
Now, given the specs of each PC below, will I have enough PCI Express Lanes or bandwidth to be able to actually achieve 10 Gbps transfer speeds each on the 2 ports of the NIC simultaneously?
PC1:
Intel i7-3770K OC to 4.6 Ghz
Asus Sabertooth Z77
(4GB X2) 8GB DDR3 1866 Mhz XMP Memory
MSI GTX 980 on PCiE 3 x16 port; no other PCiE slots on the motherboard are being used.
2 X 1TB SSDs
1 X 4TB WD Blue HDD
*Want to connect the 10 Gbe Intel X550-T2 NIC on the last (bottom most black slot, #6 as per the manual) PCiE 2 X16 slot.This slot also shares bandwidth with 3 other PCiE 2 x1 slots; non of which are not being used.
PC2:
Intel i7-4790k at Stock Speed
Asus Z97-AR
(8GB X4) 32GB DDR3 1600 Mhz Memory
MSI GTX 980Ti on PCiE 3 x16 port; no other PICE slots on the motherboard are being used.
1X 512GB SSD
2 X 2TB WD Black HDD
*Want to connect the 10 GbE Intel X550-T2 NIC on the second PCiE 3 x16 slot, which means my GTX980ti will be running at x8 instead of x16. According to my internet research, this will not cause any performance drop on GPU.
PC3:
Intel i3-4130
AsRock Z87 Pro 3
(4GB X 2) DDR3 1866 Mhz
1X 512 7200 rpm boot HDD
2X 8TB Seagate Archive v2 HDD
2X 6TB HSGT HDD.
* No PCiE ports are being used on the motherboard. Plan to connect the 10 GbE Intel X550-T2 NIC on the PCiE 3 x16 port.
So, you guys think I can get dual 10 Gbps transfer speeds or will I be bottlenecked by lack of PCI Lanes? The intel X550 Nic needs PCI 3 x4 interface, but I can only provide that in only PC3. The other 2 PCs (PC1 and PC2) will have to use PCiE 2 x16 ports
PC1:
Asus Sabertooth Z77
2 X 1TB SSDs
1 X 4TB WD Blue HDD
PC2:
Asus Z97-AR
1X 512GB SSD
PC3:
Intel i3-4130
AsRock Z87 Pro 3
2X 6TB HSGT HDD.
