Well, I've been having trouble connecting to the Internet for about a month now, off and on.
For some strange reason, my computer refuses to detect the ethernet cable connected to it, thus, my computer fails to see any connectivity, resulting in a "A network cable is unplugged" icon to remain in my taskbar. I've already tried switching cables, and that didn't work.
I began thinking that perhaps the problem is due to corrupted drivers. I booted into Safe Mode, and uninstalled the NIC device from my machine, and reinstalled the drivers, no go.
Well finally, I started to come to the conclusion that perhaps my onboard NIC just decided to die. So, I went to CompUSA and picked up a cheap $10 NIC. When I got home, I once again booted into Safe mode, uninstalled the onboard NIC device, and I also went into the BIOS and disabled "Onboard Ethernet." Once that was all finished, I installed the new NIC into an available PCI slot, booted up the machine, installed the included drivers, and... Windows XP fails to detect it.
I'm sure you can imagine how frustrated I was, but I decided to remain calm and go back to CompUSA and pick up a different NIC from another company. And Windows XP, yet again... fails to detect the new NIC. Ergh! I felt like throwing the monitor. But guess what! when I took out the new NIC, my old onboard NIC decides to start working again! YAY! Except it quits working again after a week... and then mysteriously works again! YAY! And then quits working again.
I'm at a complete loss as to what I should do. I appreciate any help on this conundrum I've been experiencing for about a month now.
(Edit: I forgot to mention that the computer I'm having trouble with is connecting to a wireless router, a D-Link DI-624, which also doesn't detect any connectivity either. (No LED lights up,) I don't suspect the router to be apart of the issue as I've been experiencing this problem when I would connect it straight to the Cable Modem.)
Anyway, here are my system specs:
Intel Pentium 4 @ 2.53 GHZ.
512 MB DDR Ram. 80 GB HDD.
Geforce 4 MX 440. (no kidding.)
VIA VT6103 10/100 Mbps Fast Ethernet Adapter.
ECS P4VXASD2+. (»ecsusa.com/products/p4vxasd2_v5_plus.h..)
VIA VT8235 South Bridge.
