PCI slot - Fan coolers.
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hello all:
I'm planning on O/C my 9500 pro and bought a PCI slot "AGP" cooler. I've
installed it and noticed an immediate drop in case temps : )
My question is:
I've installed it in the PCI slot directly below the Vid card and I figure
that since the two fans are more or less "fighting" for the same air, both
fans must work harder than they normally would. I wanted to make sure that
it doesn't interfere or shorten the life span of the actual Vid card fan.
Should I drop the addon fan to the next PCI slot?
Derek
Derek wrote:
> Hello all:
> My question is:
> Derek
I have been using one with my 9700 Pro since it came out and have never
had any problems. It was needed in my case as a lot of 3D games were
crashing after 15 minutes and the video card was almost too hot to touch.
Actually, the vid card fan is doing LESS work. Here is how. Your pci fan
blows air on the agp, thus air is more dense below agp. So your vid fan card
is now moving more air per cycle, than before.
It is very cheap and effective way to increase cooling.
"Derek" <bob@home.com> wrote in message
news:WNNwc.686806$oR5.487374@pd7tw3no...
> Hello all:
> My question is:
that
> Derek
Some PCI slot coolers exhaust air from the case (instead of blowing air into
the case) in which case the below wouldn't be true.
-Bill (remove "botizer" to reply via email)
Hello:
I should have specified that the PCI fan exhausts from the case.
Derek
"Wblane" <wblane@aol.combotizer> wrote in message
news:20040607110043.04252.00000725@mb-m13.aol.com...
into
card
If it's directly next to the GPU fan wont it exhaust hot air from the area
next to the VC to outside the case - that's got to be a good thing surely??
BillL
news:Bb1xc.659744$Pk3.55204@pd7tw1no...
> Hello:
> Derek
> into
> card
On Mon, 07 Jun 2004 00:52:18 GMT, "Michael W. Ryder"
<mwryder@_worldnet.att.net> wrote:
>Derek wrote:
>> Hello all:
>> My question is:
>> Derek
A good case would resove that issue. But not all cases are that good
>>Derek wrote:
>>>Hello all:
>>>My question is:
>>>Derek
I don't know if that is necessarily true. With PCI cards being upside
down so that all the hot parts and the fan are below the card there is
no easy way to move the hot air away from the card without an exhaust
fan in the area. If all GPU, heat sinks and fan were above the card so
that the normal air flow would move the air to the rear exhaust fan your
statement would be true, but that is not how PCI cards are made.
Maybe with a properly placed side fan exhausting the area, but the PCI
slot fan was cheaper and easier to implement.
> Hello all:
> My question is:
that
> Derek
I tried an Antec slot fan leaving an extra pci slot between a 9800 pro and
the fan. The case temperature did not change so I removed the fan. Based
on your results I will try it next to the agp slot next time I open the
case.
I do not recall the gpu load during this test. But the gpu temp is going to
change significantly under heavy load so that's the condition under which
you should be making the measurements.
On Mon, 07 Jun 2004 11:49:27 GMT, "AseStar" <a s e s t a r @ s t a r t
.. n o> wrote/replied to:
No, the slot fans blow air out of the case. The 9800 fan blow air away
from the card. Therefore the slot fan will take that air directly out
the case. Both fans will work normally .
"Michael W. Ryder" <mwryder@_worldnet.att.net> wrote in message
news:l0dxc.46932$_k3.1170954@bgtnsc05-news.ops.worldnet.att.net...
It is true. In thermodynamics, a heatsink that faces down, has lowest
efficiency.
Facing upward is good, but vertical position (air on both sides) is best. I
think the last was the INTENDED position of pci (and agp) cards when the ATX
was created. Remember original idea was to have desktop chassis (lying down
on desk) hence all cards would be in vertical position..
Too sad, the towers just about killed the cooling.
On Wed, 09 Jun 2004 11:23:30 GMT, "AseStar" <a s e s t a r @ s t a r t
>efficiency.
I guess it's down to whatever bright spark decided to mount the mobo
on the right side of the case and access it from the left, rather than
the other way round.
That would also put the CPU (usually) at the bottom rather than the
top of the board, where it should be cooler (certainly with good
throughflow of air), and a big heatsink could be supported and
wouldn't have problems fouling the PSU. And that's quite apart from
having the heatsinks on top of the cards! Brilliant decision, eh?
patrickp
patrickp@5acoustibop.co.uk - take five to email me
I've got the fan card that's twin fans facing the AGP card.
Doesn't get any heat out of the case, but HAMMERS the AGP card pretty
good when you turn it up. There's a slider for speed control, but I
hooked it up to a fan speed controller that allows me to turn it off
completely when I'm not playing games.
I'd figure it would be a bad thing because both fans would be drawing air from
the same location and, if they're directly opposite to each other, reducing
the air flow that either fan gets by applying forces in directly opposite
directions.
>BillL
>>efficiency.
That would be intel who did the ATX spec. Remember, mobos were
originally designed for DESKTOP computers in which the CPU pointed up
and the expansion cards were vertacle, rather than to the side. When
they went with PCI/AGP, the reversed the cards to "point down" for
some odd reason, I think to allow a PCI & ISA slot share the same area
(otherwise you would lose a slot)
BTX flips the board around.
BTX again... the PSU is generally still on top, with the expansion
cards.... With INTEL making very HOT cpus (more than AMD) the new
design was needed.
Remember: In the USA - it is dangeroud to draw or write about Heir Bush in a negative way. The police or SS are called, people threaten to kill you. (What country is this again?)
- 15yr old boy in Washington was disciplined for drawing such images.
- White House blows cover of an undercover agent because her husband said there were no WMD (before the USA started the war) - her job was finding terrorist. (This makes sense?)
God bless the land of the free. Where you can burn the Constitution... Ashcroft does it every day.
