PCI to VGA card
eighthwonder
30
Hi guys, please suggest to me some thing like this for windows 10 because i don't want to throw away my perfectly working monitor because the motherboard doesn't have a VGA port, my monitor has only VGA port.
http://www.ebay.in/itm/8-MB-PCI-VGA-Card-PCIVGA-Card-box-pack-Shipping-Bluedart-Aramex-Indiapost-/111739868227?hash=item1a04371443:g:COkAAOSw-W5UyyoT
for this motherboard,..... i am going for this board because of Max. shared memory of1792MB no other LGA. 1151 board has Max. shared graphics memory of 1792MB. and it fits very well in my budget and enough for my needs.
i live in India.
http://www.asrock.com/mb/Intel/Fatal1ty%20H170%20Performance/
The card you have linked is one of the old standard PCI cards. What you should be looking for is a PCI-E card like the one Birdo suggested. It is Windows 10 compatible and all you would need is a DVI to VGA adapter that typically comes with the graphics card.
The card you linked *MIGHT* work with standard Windows 10 drivers, but I wouldn't bet on it. Look for a PCI-Ex16 graphics card with either a native VGA or DVI-I port with a DVI to VGA adapter.
-Wolf sends
get a better GPU like a Gt 720 at least or just use the intergrated one but if those cards dont have a vga plug in then buy a DVI To VGA thingy lets u use a vga cable and plug it to the dvi side with the thing because that 8mb card wont play HD quality anything and things will be really slow
thanks for answering, that card is enough for my needs, i want to know if there is something like that for windows 10.
-Wolf sends
