PCIE 2.1 card on PCIE 1.0 mobo.. HELP!
Feb 14, 2013
24
My mobo is MSI g41m-p28 heres the specs: http://www.msi.com/product/mb/G41M-P28.html#/?div=Basic
as you can see its only pcie 1.0 (correct me if I'm wrong)and I'm going to buy a Powercolor Radeon HD 6670 which is a pcie 2.1.. I read some topics online and some say 2.1 cards have a 50/50 chance working on a pcie 1.0 depending on the mobo, is this true? do you think my mobo can handle the 6670 without any problems? or I should just stick to 2.0 cards just to be safe? I'm going to buy the graphics card on Tuesday, Any help will be appreciated. thanks!
The G41 chipset supports PCI-E 1.1 (http://ark.intel.com/products/36528/82G41-Graphics-and-Memory-Controller-Hub) so there should be no problem.
I have an Asrock G41 board and use a 6670 no problem
It should work it just won't be overly awesome! I've never experienced any problems using newer cards on older gen PCI-E just get slightly slower data than the newer gen would get. nothing much to worry about
Thanks for the fast reply people I appreciate it. I'm going to update the BIOS now. The latest update is 2012-12-10. I found a review on cnet about this board it seems he can use a 6770 on this board which is a 2.1 pcie card. I'm going to report back if my 6670 works as soon as i can test it. Wish me luck!😀
