[SOLVED] PCIE Cable for CX430M?
I have an R9 270X and FX-8320, should I be concerned? These components are quite dated as well.
Yeah, you should be concerned. The 270x requires 2x6 pin cables and draws 200w+. The cpu also can draw up to 150w+.
Generally, if a psu doesn't have enough cables or the proper cables, you get a different psu. This case is not an exception, unless you don't mind potentially having a dead system.
Waitwaitwait, hold up. What are you trying to power? A cx430 is not a psu you want to use with any modern pc, let alone a gpu with two pci-e cable connections. The cx430 has cheap components, and with a low 12v wattage of 380w, any heavy load will probably kill the psu or worse.
