PCIe Lanes question for 960 pro
mb7756
7
Hello, I have a 6700k, z170 board, gtx 1080, sound blaster Z pcie card, 2x sata 850 pro's, and 3x sata WD black 1tb drives. Just ordered an m.2 960 pro. I do not understand how lanes work. Can I just drop in the m.2, or will I have lane issues with this configuration? I could remove the 2x 850 pros if needed but I'd prefer max performance from the m.2 and 1080 if this setup will be crippling.
Thanks!
you will be fine , your M2 is shared with PCIEx4 slot number 3 ..
when you enable the M2 from the bios it will disable that slot.
Read the Manual carefully ... maybe you need to change where you put your sound card.
your motherboard ?
in General you can Just install it in your M2 and make sure not to use the SATA port that is shared with it. you can read the manual to know which SATA port is shared with it.
no need to remove any drives or SSD you already have ..
My manual says:
"This motherboard features an M.2 slot, which supports both PCIE and SATA modes. The PCIE mode operates at full PCI Gen. 3.0 x4 speeds. The SATA mode shares bandwidth with PCIEX4_3 and will automatically be disabled when a PCIe device is inserted."
