So i bought a PCIe power cable from Ebay because i didn't have one and my GTX 1070 has just got here so i ordered this from ebay: http://
So it takes 3 days to get here and i'm ok with that. Then when it gets here, i try to plug it in. It just doesn't work so i find this part of the connector where there is plastic that is not allowing it to go in. So i cut it and i try again, didn't work. I cut some more it doesn't work! So then i got rid of the plastic i cut it finally goes in and stays in but..... my computer tells me to connect the PCIe cable still. The cables are fully plugged in. Here are some pictures: http://
Let me note a couple things: On the plastic packaging it says "For SilverStone PSU's only, refer to website for details". When i went to the ebay page it said NOTHING about it being SilverStone exclusive. So i went to amazon to read some reviews and it was exactly as i expected it to be.
Here is a review from amazon to explain the cable: Once modified to remove the bridge between two connectors, the cable worked fine. Rating between 2 and 3 purely subjective. It is a very good cable, but time was wasted identifying and then correcting the problem. Almost returned it, except I could not not find an alternate. Modifying a product should not be necessary in order to have the product function properly.
So now i'm thinking about just going to a small computer shop and seeing if they have any cables because no else sells them really. Not even Best Buy or Staples.
Thanks for the read and your help, if you need any more info, ask.
