I recently ran out of SATA ports on the PC I'm using as a server for my Plex Media Server so I decided to purchase an expansion card, specifically
Overall, things seem to be working fine with just a minor hiccup. If the drives I have plugged into this card are accessed after being idle for an extended period of time, it often takes a few seconds to boot up. Usually this isn't a problem but when it comes to Plex (specifically while accessing it through something like a Fire stick HD), sometimes it gives an error message or takes more than a few seconds before the movie is able to load up.
Is there any power setting that I can enable or disable that can fix this issue, or any thoughts at all on what I'm experiencing? Thank you!
