[SOLVED] PcSpecialist build for £1000
JustWantaDecentTv
11
So I'm mainly buying this to play strategy games. Humankind or crusader kings and the like. S o I was looking for some configuration advice from the PcSpecialist site. Thanks.
Or if you want to build something for yourself,
PCPartPicker Part List
CPU: Intel Core i5-11400F 2.6 GHz 6-Core Processor (£148.35 @ CCL Computers)
CPU Cooler: CRYORIG M9 Plus 48.4 CFM CPU Cooler (£25.99 @ Currys PC World)
Motherboard: MSI MAG B560M MORTAR Micro ATX LGA1200 Motherboard (£109.99 @ Box Limited)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (£48.90 @ Overclockers.co.uk)
Storage: Kingston A2000 1 TB M.2-2280 NVME Solid State Drive (£78.83 @ More Computers)
Video Card: Asus Radeon RX 6600 XT 8 GB DUAL OC Video Card (£513.48 @ Ebuyer)
Case: Corsair 4000D ATX Mid Tower Case (£49.98 @ Amazon UK)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply (£52.98 @ Amazon UK)
Operating System: Microsoft Windows 10 Home OEM 64-bit (£89.55 @ Box Limited)
Total: £1118.05
Generated by PCPartPicker 2021-12-13 12:20 GMT+0000
At least fully knowing what is inside of the pc.
If the system you chose yourself realy has that Asus TUF board in it would that be fine, question mark is still the psu used.
Above system by RARRAF looks decent too, psu is also a decent one with that Corsair CX650F. The motherboard is imo really basic, but will do the job. Would pick this one over your own choice.
The card is available at the time of posting...
Type|Item|Price
CPU | Intel Core i5-11400F 2.6 GHz 6-Core Processor | £148.35 @ CCL Computers
CPU Cooler | Deepcool GAMMAXX 400 Blue 74.34 CFM CPU Cooler | £25.47 @ Scan.co.uk
Motherboard | Gigabyte Z590M GAMING X Micro ATX LGA1200 Motherboard | £130.16 @ Amazon UK
Memory | Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory | £48.90 @ Overclockers.co.uk
Storage | Crucial P5 500 GB M.2-2280 NVME Solid State Drive | £50.99 @ Amazon UK
Video Card | Palit GeForce RTX 3060 Ti LHR 8 GB Dual Video Card | £649.99 @ Technextday
Case | Zalman S2 ATX Mid Tower Case | £39.99 @ Technextday
Power Supply | Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply | £59.99 @ Ebuyer
| Prices include shipping, taxes, rebates, and discounts |
| Total | £1153.84
| Generated by PCPartPicker 2021-12-13 12:32 GMT+0000 |
Just curios why your thread title is pcspecialist build for £1000 and then you post a link to argos.
Anyways , regardless of that i can tell you that pc specialist are very good at what they do , they even advertise if you find your build cheaper tell us.
I have a very expensive games rig from them and a cheaper every day rig that i use to try thing on before i put them on my main rig.
First look at the required specs for games you intend to play and then go back to the build my pc column on their website , at the end of the process their system will check for mismatched parts or overkill such as too big a power unit.
If you do go with them take out the breakdown insurance , i did and was glad i did because 1 year later some of my ram died.
Also if you have a side fan it will not be connected when you get the pc because the wire would snag on their special transit packing.
