Performance Problem GTA V, Please Help
Matthew_16
12
So These are my specs, a bit back I had stuttering but it was after I played for and hour or more but now its gotten to a point where its unbearable.
GPU: Nvidia GeForce GTX 780
CPU: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
RAM: 16GB Corsair Vengeance
Ambient Occlusion: Normal
Anisoptric Filtering: x16
Distance Scaling: 100
Extended Distance Scaling: 100
Extended Shadows Distance: 0 ***
FXAA: On
Grass Quality: High
High Resolution Shadows: Off
In-Game Depth Of Field Effects: Off
Long Shadows: On
MSAA: x2
Nvidia TXAA: Off
Particles Quality: Very High
Population Density: 100
Population Variety: 100
Post FX: High
Reflection MSAA: x2
Reflection Quality: Very High
Shader Quality: High ***
Shadow Quality: High ***
Soft Shadows: Nvidia PCSS
Teslleation: Very High
Texture Quality: High
Water Quality: High ***
Anything with a star means that my GeForce Experience recommened it higher for optimal gameplay.
Extended distance scaling, that will drop your fps considerably. You may as well turn Post FX and FXAA off as you have MSAA on, the game will look clearer. Soft shadows set to sharp or sharpest looks the best.
Note: Don't let geforce experience configure your settings for you, do them manually and test out what works, it's better.
