Performance Problems need diagnosis
AC_V3GAS
27
OS Name: Microsoft Windows XP Professional
MotherBoard: Asus AV8 Deluxe Rev 1.xx
BIOS Version/Date: American Megatrends Inc. 1017.002, 14/11/2005
PSU: HEC 385AD-PT -> Total Output: 385W -> Intel Ver1.3 ready -> ATX 12v
Graphics: ATI Radeon X1950 GT AGP 256MB (Dual Screen) -> Driver: 8.421.0.0 28/09/2007 -> CCC: 2007.0928.2231.38404
Processor: AMD Athon 64 3500+ 2200MHz -> Driver: 1.3.2.0 27/05/2006
Memory: 1.50 GB
I keep my machine pretty well maintained and up to now I have been happy with performance but last week I upgraded my graphics card from the 9800PRO to the card specified above. In games I have noticed a reasonable increase in performance but in windows it seems as though performance may have degraded since the upgrade. I initially thought that this might be down to my PSU but I have not had any crashes or overheating problems. I have upgraded every driver I can think or including processor, chipset and graphics drivers. I ran 3DMark05 and got the following result:
3DMark Score 9318 3DMarks
CPU Score 129 CPUMarks
I was expecting higher from my graphics card so i still believe it should be performing better but my CPU was ridicules! Has anyone else got a CPU score that low??!
Could this be a Driver/BIOS setting/Configuration/Application issue rather than my hardware. I really want to get the most out of my machine because I don't think that is what I am getting. Any help would be greatly appreciated.
I bought the card so I could play the latest games including DiRT. I have the Demo but performance is not great and I'm sure my system should be able to run it at 1024/768 without issue but it definitely struggles.
I am planning my next upgrade to be a new processor hopefully a AMD X2 4400+ as my Mobo is still hanging in there with a socket 939 but that might not be in the near future. Is this a good plan or do you think a new PSU would be a better upgrade at this point.
Please just ask if you need any further information.
Grimmy
Splendid
Feb 20, 2006
4,431
3dmark05 is still pretty hard on older AGP systems. My older P4 system with 6800GS AGP only scored at best 4500ish.
With my new system, E4400 (2.8ghz when I tested) paired with 8800GTS 320MB, scored 15,300ish:
So I'd say if you want a better rig to handle todays games, you should save up to build yourself a new rig, whether is AMD's path or Intels path.
Edit:
Almost forgot to mention the 8800 GT cards in Nov should be good as well.
AC_V3GAS
27
I realise a new machine would be best but I really want to get the most out of the one I have for another year or so. Especially as I've just bought a new Graphics card.
Grimmy
Splendid
Feb 20, 2006
4,431
Well.. I've been in the same situation. I've upgraded my P4 2.66ghz, to a P4 3ghz. Even though I didn't spend much to try to get lil more out of that system, in the long run it really didn't matter. However, I'm still using it for my linux setup. So not all was lost in keeping that system running, with better hardware.
Not sure, but you might have something wrong. Here's my old system results I saved online awhile back:
3DMark05 Project Details
Doh.. above link doesn't work when I logged out. :lol:
That one should werk.
My old P4 3ghz did score: 3442 CPUMarks
I tried to compare my old to AMD 2200mhz with X1950 pro:
Main Test Results
3DMark Score
(3DMarks)
5014 <-mine
8464 <-AMD
CPU Score
(CPUMarks)
3442 <-mine
3821 <-AMD
Heh, so your system scored higher then mine or the compared one, but yet your CPU score is wrong. That's kinda weird, unless that was a typo for 129 on cpu score.
AC_V3GAS
27
My Result Details:
Main Test Results
Detailed Test Results
Game Tests
GT1 - Wings of Fury 163.9 fps
GT2 - Battle of Proxycon 84.2 fps
GT3 - Troll's Lair 53.7 fps
GT4 - Mother Nature 64.1 fps
CPU Tests
CPU Test 1 21.1 fps
CPU Test 2 1.2 fps
Feature Tests
Fill Rate (Single-Texturing) 2963.1 MTexels/s
Fill Rate (Multi-Texturing) 5742.8 MTexels/s
Vertex Shader 27.8 fps
Pixel Shader 2.0 85.0 fps
Ragtroll 42.9 fps
Sound Tests
No sounds 47.7 fps
24 sounds 38.0 fps
60 sounds Not Supported
AC_V3GAS
27
My Configuration:
Components Your System
Processor AMD Athlon(tm) 64 2203 MHz
Physical / Logical CPUs 0 / 0
MultiCore N/A
HyperThreading N/A
Graphics Card Generic VGA
Graphics Driver ATI Radeon X1950 GT Secondary
Linked display adapters No
DirectX Version 9.0c
System Memory 1536 MB
Disk Space N/A
Motherboard Manufacturer ASUSTeK Computer Inc.
Motherboard Model A8V Deluxe
Operating System Microsoft Windows XP
Grimmy
Splendid
Feb 20, 2006
4,431
Huh? :lol:
That system is now a FC5 Linux machine. It originally had a retail P4 2.66ghz 533FSB CPU (5 years old stil have it). I upgraded it to a P4 3ghz 800 FSB CPU (Sept 2006) before the C2D (they were too expensive at the time) came out and the prices fell on it.
I've only had my new build for a lil less then a month, with the E4400.
Grimmy
Splendid
Feb 20, 2006
4,431
I'm not sure, but I'd say you wouldn't get better performance.
Have you tried looking at DirectXDiagnostic Tool? Which is found;
C:\WINDOWS\system32\dxdiag.exe
That should tell you if you do have any DX driver problems.
Reynod
Administrator
No. Plau with the system a bit more before trying Vista.
Simply get an X2 dual core CPU - socket 939.
There are plenty still floating about - -should get it cheap.
FX60 - fastest ... expensive.
4800+
4600+
4400+ good price point - 2 X 1Mb cache ... can OC to 4800+ easy
4200+
3800+
The OPT dual core's will also run on this ... better silicon to OC usually too.
Hope this helps.
HEC psu are good but what is your 12V amps? If the GPU recomments are 29amps on the 12V rail yours might be a bootleneck. If you are planning to go for the dual core I would start with the psu.
AC_V3GAS
27
But if my PSU was a problem wouldn't I be getting more serious problems like crashes etc.. My system is pretty stable.
nukemaster
With a X1950GT being an underclocked X1950Pro(correct me if this is wrong...). So power should not be an issue at all....a X1950Pro only uses ~66 watts(5.5 amps).
That should leave plenty left for the rest of the system
I will go check the cpu score on a Athlon 64 3200+ and report back...
EDIT
Results
cpu : 4003 (Athlon64 3200+ 2200mhz socket 754 single channel ram Cool n Quiet : ON)
Check you task manager to make sure something is not sucking up all your spare cpu power. 129 IS low......
Also check with CPU-Z to make sure your running at the right speed. You can also try to disable cool n quiet in the bios to see if its related(maybe your cpu is staying clocked down)
AC_V3GAS
27
I've got Asus Probe installed and that reports that my CPU is running at 2200MHz(Current Speed) as it should. Before I ran the test I closed everything I could including Anti virus etc..
My processor does seem to max out at 100% far too often. I don't know how accurate the CPU usage is on the G15 Keyboard but in games it is pretty much always on 100% and even some basic windows tasks can use all processor resource.
Is there any other way just to test my CPU? something must be wrong with it
gomerpile
2,293
11
ya get ubcd and run some test
http://www.mrbass.org/ubcd/
Its the best in testing should do ya just fine, Yes a new psu you will need it for future systems.
AC_V3GAS
27
Should I just get this processor looks good and I can get it for £44.64 Inc VAT seems like a pretty good deal! Will my machine cope with it in it's current state and will my stock 3500 CPU fan be suitable for this one:
Manufacturer: AMD
CPU Type: Athlon 64 X2
Socket: 939
CPU Model: 4200+
Core: Toledo
Core Size: 90 nm
Clock Speed: 2.2 GHz
FSB/HT Speed: 2000 MHz
L1 Cache (Total): 2x 128KB
L2 Cache (Total): 2x 512KB
L3 Cache (Total):
Voltage: 1.3 (V)
AC_V3GAS
27
Just noticed the ATHLON 64 X2 4400+ has 2 x 1024kb L2 Cache and this only has 2x 512KB L2 Cache. Will there be much difference in performance?
Will this CPU bring my PC at least up to a reasonable modern standard to keep me going for the next couple of years? Really can't afford a new rig at the moment.
nukemaster
For a new cpu you will have to check asus's website to make sure your current bios supports it(or see what bios you need and flash it). the extra 512k of cache makes a small difference(about the same as having the cpu run 100mhz or so faster)
First i think your should try to see why your cpu score is so low. Did you ever test with your old card? maybe there is some kind of a compatibility issue running the new card? Check asus for any such known problems or bios updates...
CPU usage of 100% while in games is normal. but if you get it at idle its not(unless you are folding. then its 100% all the time like me :) ).
AC_V3GAS
27
Surley 3DMark Score 9318 means my graphics card is running ok.
It's the CPU Score of 129 thats worrying. I have had this CPU and motherboard together for almost 3 years. Could it be compatibility between the Graphics card and the CPU.
AC_V3GAS
27
Just ran 3DMark again after closing a few more processes and I improved a little:
3dMark 9429
CPU Mark 130
I also ran it with an Energy Monitor in and my PSU never even registered above 185Watts so I don't think my 385W Power Supply is the problem.
Is anyone else running using the A8V Deluxe with an AMD 64 Processor and the Sapphire X1950 GT or similar?
System Info Detail Below:
CPU Info
CPU 1/1
AMD Athlon(tm) 64 Processor 3500+
Manufacturer AMD
Family AMD Athlon(tm) 64 Processor 3500+
Architecture 64-bit
Internal Clock 2.2 GHz
Internal Clock Maximum 2.2 GHz
External Clock 200.0 MHz
Socket Designation Socket 939
Type Central
HyperThreadingTechnology N/A
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE, SSE2, PAE, NX
Version AMD Athlon(tm) 64 Processor 3500+
Caches
Level 1 128 KB
Level 2 512 KB
DirectX Info
Version 9.0c
Long Version 4.09.00.0904
DirectDraw
Version 5.03.2600.2180
Primary Device ATI Radeon X1950 GT
Display Device 1/2
ATI Radeon X1950 GT Driver 6.14.10.6727
Description ATI Radeon X1950 GT
Manufacturer ATI Technologies Inc.
Total Local Video Memory 256 MB
Total Local Texture Memory 256 MB
Total AGP Memory 0 B
Driver File ati2dvag.dll
Driver Version 6.14.10.6727
Driver Details 8.421-070928a-053250C-ATI
Driver Date 9-28-2007
Driver WHQL Certified true
Max Texture Width 4096 px
Max Texture Height 4096 px
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 3.0
Pixel Shader Version 3.0
Max Vertex Blend Matrices 37
Max Texture Coordinates 8
VGA Memory Clock 0.0 Hz
VGA Core Clock 2.3 MHz
PCI
Name ATI Radeon X1950 GT
Vendor ID 0x1002
Device ID 0x7288
SubSystem ID 0xe190174b
Revision ID 0x009a
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [UYVY]
FourCC [YUY2]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Texture Border Color, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
Display Device 2/2
ATI Radeon X1950 GT Secondary Driver 6.14.10.6727
Description ATI Radeon X1950 GT Secondary
VGA Core Clock 0.0 Hz
PCI
Name ATI Radeon X1950 GT Secondary
Vendor ID 0x1002
Device ID 0x72a8
SubSystem ID 0xe191174b
Revision ID 0x009a
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [UYVY]
FourCC [YUY2]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
DirectShow
Version 9.0c
Registered DirectShow Filters
.RAM file Parser
AC3 Parser Filter
ACELP.net Sipro Lab Audio Decoder
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASF embedded stuff Handler
ASX file Parser
ASX v.2 file Parser
ATI MPEG Video Decoder
ATI Media Center Audio Encoder
ATI Media Center Multiplexer
ATI Media Center Video Encoder
ATI Time Shift Reader
ATI Time Shift Splitter
ATI VCR Stream Source
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
Color Space Converter
Creative AC3 Source Filter
Creative CDDA Source Filter
Creative Flac Source Filter
Creative Internet Source Filter
Creative LiveRecording Filter SxS
Creative MLP Source Filter
Creative NVF Filter
Creative Ogg Source Filter
Creative WMA Source Filter
DV Muxer
DV Splitter
DV Video Decoder
Decrypt/Tag
Default DirectSound Device
Default MidiOut Device
DivX Decoder Filter
DivX Demux
DivX Subtitle Decoder
File Source (Async.)
File Source (Netshow URL)
File Source (URL)
File stream renderer
Indeo audio software
Indeo video 4.4 Decompression Filter
Indeo video 5.10 Decompression Filter
InterVideo Audio Decoder
InterVideo Audio Processor Fx
InterVideo MPEG4 Video Decoder
InterVideo Video Decoder
Internal Script Command Renderer
Line 21 Decoder
Line 21 Decoder 2
MIDI Parser
MJPEG Decompressor
MPEG Audio Decoder
MPEG Layer-3 Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Splitter
MPEG-I Stream Splitter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
Multi-file Parser
NSC file Parser
Overlay Mixer2
QT Decompressor
QuickTime Movie Parser
SAMI (CC) Parser
VBI Surface Allocator
VGA 16 Color Ditherer
Video Port Manager
Video Renderer
WM ASF Reader
WM ASF Writer
WST Decoder
Wave Parser
Windows Media Audio Decoder
Windows Media Multiplexer
Windows Media Update Filter
Windows Media Video Decoder
Windows Media source filter
XML Playlist
DirectSound
Version 5.3.2600.2180
Speaker Configuration Stereo
Speaker Geometry Wide
Primary Device Realtek AC97 Audio
Sound Device 1/1
Realtek AC'97 Audio for VIA (R) Audio Controller Driver 5.10.0.5530
Description Realtek AC97 Audio
Manufacturer Realtek
Driver File ALCXWDM.SYS
Driver Version 5.10.0.5530
Driver Date 3-19-2004
Max Supported 3D Hardware Sounds 33
HD Audio Support false
EAX Support Supported
PCI
Name Realtek AC'97 Audio for VIA (R) Audio Controller
Vendor ID 0x1106
Device ID 0x3059
SubSystem ID 0x812a1043
Revision ID 0x0060
Capabilities
Continuous Rate, Primary Buffer with 16-bit Samples, Primary Buffers with 8-bit Samples, Monophonic Primary Buffers, Stereo Primary Buffers, Hardware-mixed Secondary Buffers with 16-bit Samples, Hardware-mixed Secondary Buffers with 8-bit Samples, Hardware-mixed Monophonic Secondary Buffers, Hardware-mixed Stereo Secondary Buffers
Memory Info
Total Physical Memory 1.50 GB
Free Physical Memory 1.18 GB
Total Pagefile Memory 3.35 GB
Free Pagefile Memory 3.02 GB
Memory Array 1/1
Max Module Capacity 0 B
Supported Speeds
Supported Types
Supported Voltages
Memory Slot 1/2
Installed Enabled Size 256 MB
Form Factor DIMM
Frequency 400.0 MHz
Slot DIMM0
Manufacturer <unknown>
Type Details
Enabled Size 256 MB
Total Bit Width 72 b
Data Bit Width 0 b
Memory Slot 2/2
Form Factor DIMM
Frequency 400.0 MHz
Slot DIMM1
Type Details
Enabled Size 256 MB
Data Bit Width 0 b
Motherboard Info
Supported Slot Types ISA, PCI, AGP
Model A8V Deluxe
Version Rev 1.xx
BIOS Vendor American Megatrends Inc.
BIOS Version A M I - 11000514
BIOS Release Date 14/11/05
BIOS Properties Plug and Play, Flash, AGP
AGP
Revision 3.0
Rate 4x, 8x (8x enabled)
Available Rate 0x0000000c
Selected Rate 0x00000008
Aperture Size 245 MB
Sideband Addressing supported (enabled)
Fast Write not supported
Card Slots
Slot 1/6 (AGP)
ATI Radeon X1950 GT
Order 0
Designation AGP
Type AGP
Characteristics 3.3V, Shared, PME Signal
Data Bus Width 32 b
Details In Use, Long
Device Class Display Adapter
Driver Version 8.421.0.0
IRQ 16
Slot 2/6 (PCI)
Order 1
Designation PCI1
Type PCI
Data Bus Width 32 b
Details Available, Long
IRQ 0
Slot 3/6 (PCI)
Order 2
Designation PCI2
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 4/6 (PCI)
Order 3
Designation PCI3
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 5/6 (PCI)
Order 4
Designation PCI4
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 6/6 (PCI)
Order 5
Designation PCI5
Type PCI
Data Bus Width 32 b
IRQ 0
System Devices
Name PCI standard host CPU bridge
Manufacturer (Standard system devices)
Name WinXP Promise FastTrak 378 (tm) Controller
Manufacturer Promise Technology
Name VIA Standard Host Bridge
Manufacturer VIA
Name VIA Bus Master IDE Controller - 0571
Manufacturer VIA SATA/PATA IDE controllers
Manufacturer VIA
Manufacturer VIA
Name VIA Rev 5 or later USB Universal Host Controller
Manufacturer VIA Technologies
Name VIA OHCI Compliant IEEE 1394 Host Controller
Manufacturer VIA
Name VIA USB Enhanced Host Controller
Name VIA RAID Controller - 3149
Manufacturer VIA Technologies, Inc.
Name VIA Standard PCI to ISA Bridge
Manufacturer VIA
Manufacturer VIA
Manufacturer VIA
Manufacturer VIA
Name VIA CPU to AGP2.0/AGP3.0 Controller
Manufacturer VIA
Name Marvell Yukon Gigabit Ethernet 10/100/1000Base-T Adapter, Copper RJ-45
Manufacturer Marvell
Name SoftV92 Data Fax Modem
Manufacturer CXT
Name ASUS 802.11b/g Wireless LAN Card
USB Devices
Description USB Root Hub
Driver Date 7-1-2001
Driver Version 5.1.2600.2180
Device Class Universal Serial Bus Controller
Description USB Composite Device
Driver Version 5.1.2600.0
Description USB Human Interface Device
Device Class Human Interface Device
Description Generic USB Hub
FireWire Devices
Description 1394 Net Adapter
Driver Version 5.1.2535.0
Device Class Network Adapter
Monitor Info
Monitor 1/2
Name LG L194WT(Digital)
Manufacturer LG
Max Width 1440 px
Max Height 900 px
Monitor 2/2
Name hp f1904 flat panel monitor
Manufacturer HP
Max Width 1280 px
Max Height 1024 px
Operating System Info
Version 5.1.2600
Service Pack Service Pack 2
Windows Environment 32-bit
Locale GB
Desktop Width 1280 px
Desktop Height 1024 px
Desktop BPP 32 b
DEP
Hardware Support true
Applications Protected true
Drivers Protected true
User Option On for essential Windows programs and services only
Open Processes
Name PID Memory Usage
3DMark03.exe 1920 26 MB
AAWTray.exe 3020 396 KB
alg.exe 144 184 KB
ati2evxx.exe 944 524 KB
ati2evxx.exe 1356 1 MB
avgamsvr.exe 1684 352 KB
avgemc.exe 1736 1 MB
avgupsvc.exe 1700 328 KB
CCC.exe 4040 10 MB
csrss.exe 688 2 MB
CTDetctu.exe 3128 640 KB
CTSVCCDA.EXE 1772 80 KB
explorer.exe 2596 8 MB
inetinfo.exe 1828 2 MB
jusched.exe 3012 112 KB
KHALMNPR.exe 3312 840 KB
LCDClock.exe 3228 1 MB
LCDMedia.exe 3220 976 KB
LCDMon.exe 2968 956 KB
LCDPOP3.exe 3208 1 MB
LGDCore.exe 2940 1 MB
lsass.exe 792 2 MB
MOM.exe 3140 4 MB
PnkBstrA.exe 1976 580 KB
services.exe 780 3 MB
SetPoint.exe 3192 2 MB
smss.exe 616 176 KB
SOUNDMAN.EXE 2780 720 KB
spoolsv.exe 1568 2 MB
svchost.exe 956 2 MB
svchost.exe 1064 1 MB
svchost.exe 1160 14 MB
svchost.exe 1204 900 KB
svchost.exe 1248 2 MB
svchost.exe 2748 304 KB
System 4 108 KB
System Idle Process 0 28 KB
wdfmgr.exe 212 3 MB
winlogon.exe 732 6 MB
wmiprvse.exe 2300 6 MB
Logical Drives
Letter Label Type Capacity Available
A: Floppy 0 B 0 B
C: Hard Disk 80.00 GB 39.76 GB
D: BF2 DVD CD-ROM 1.91 GB 0 B
E: CD-ROM 0 B 0 B
F: Data Hard Disk 218.08 GB 149.75 GB
Open Applications
3DMark03 - Free Version
AMD:CCC-AEMCapturingWindow
AppWindow
Creative MediaSource Detector U
WindowsForms10.Window.8.app.0.3d893c
Hard Disk Info
Hard Disk Drive 1/1
Name ST332062 0AS SCSI Disk Device
Manufacturer (Standard disk drives)
Capacity 298.09 GB
Model ST332062 0AS SCSI Disk Device
Interface Type SCSI
Similar threads
