So I recently swapped out parts to a 4690k and Asrock z97 Fatal1ty.. One day after I put in a new Soundcard the computer wouldn't boot. It would power up and power down after a second or two continuously until I turned off the power switch.
Eventually from playing around with it, I unplugged the 8pin power to the motherboard and cmos reset it and it worked. Yay! But after this, small vibrations would make my computer freeze on the current screen. I didn't think it was a big deal for a bit because I would work around it and prevent it from happening.
So I woke up in the middle of the night last night to get on the computer... The computer froze for no apparent reason. When I tried turning it on it would do the same thing.. on and off constantly. So I said okay I'll fix it tomorrow (today). Nothing has worked so far.. At most I can get the computer go boot and go beep beep but I get no signal nor power to my peripherals.
What I've tried:
CMOS Jumper Reset
Reseating
Testing RAM individually
Replugging peripherals
Taking it all apart and reseating the whole thing
I've tried changing Motherboards
I just keep getting the same results, no power or signal to the peripherals.. I could run out and buy a new motherboard to test to see if its toast but I need someone else to say it 🙁
What I've tried:
CMOS Jumper Reset
Reseating
