[SOLVED] Peripherals Won't Work After Overclocking
TechFailsz23
18
So, last night I tried overclocking my PC to Frequency 0 and Voltage 1. I believe I also turned on that setting that makes game play better but reduces idle power (I don't remember the name of the setting, something like "CPUcom"? I'm not sure.) After turning my PC off and on again, the monitor I used would not connect to my computer. None of the RGB on my mouse or keyboard lit up, and was unresponsive. I looked at the back, to check all the USB's were okay, and they were. HDMI was plugged into the GPU, which, after looking, came loose while the PC was on. (Not sure is the GPU is broken too.) After putting the GPU back in position, the PC still wouldn't connect to the peripherals. Please help!!
Components:
Ryzen 5 3600 CPU
Corsair H60 CPU Cooler
Gigabyte DS3H B550M MoBo
16g OLOy RAM
Phantom Gaming RX 580
2TB HDD
222GB SSD
500w PSU
Cooler Master MB311L ARGB Case
  • Shutdown PC
  • Flip PSU switch to off
  • Unplug from wall
  • Press power button and keep it pressed for 15 seconds
  • Remove battery from the board and come back after 10 minutes
  • Put battery back
  • Plug in the wall
  • Flip PSU switch to on
  • Start system
  • Shutdown PC
  • Unplug from wall
  • Put battery back
  • Plug in the wall
  • Start system
