permanent shift click
waqaramini78
230
Ok so i was playing mc and suddenly about 2 days ago it wouldnt let me pick up anything' ie it was as if i was holding shift. Now suddenly if i go on google or anything where i need to type, whenever i put in numbers they come up as symbols as if im holding down shift. And this is exactly the same with minecraft. When i try to type it comes up as shift. Same as when i pick up items from my inventory... they wont pick up. Someone pls help
Did it prompt you to turn sticky keys on/off? Disconnect the Keyboard, give it a sec, reconnect it. Try a reboot yet? The key could just be stuck or the keyboard is dirty or it got wet. Tapping shift 5 times will turn sticky's on/off
Here's a way to turn them off in the control panel too...http://www.techrepublic.com/blog/windows-and-office/quick-tip-disable-the-sticky-and-filter-keys-in-windows/
Do you have another USB keyboard to try? Just so we can rule our the keyboard itself?
Yes, on the bottom left of the Windows Login screen, Click the little blue and white logo (ease of access)
Select the box that says - Type without a keyboard (onscreen keyboard)
Click Apply, use the on screen keyboard
Ok this is the problem. I have logged out of windows so i cant access anything and because i have perma shift click the numbers i have in my password turn into symbols. Also i only have the keyboard i sent before and i have unplugged it but i can plug it back in
Latest posts
