Hello tech experts,
Read on the forums first and tried a few of the fixes, didn't see anything that worked so I'm posting here.
Running a custom built desktop PC with Windows 7. Intel i5-3570K @3.4 GHz. 8 GB Ram. 64 bit Windows. Asus pce-n15 wireless card. Netgear N600 WiFi Cable Modem Router Model C3700.
Okay so this wireless network had been giving me no trouble before I left for vacation and once I came home the wireless card was having trouble identifying the network but after a long period of time with many tries it would eventually connect by what felt like luck. Today however, it was unable to connect at all so I attempted the standard unplug, plug back in of the router to no avail. I have since tried some of the command prompt fixes with no results. I've tried forgetting the network, reinstalling the wireless card driver, removing and readding the card in device manager, restoring my computer to day 1, and ritualistic sacrifice, but still with no results. My computer recognizes the network and names it with excellent connectivity. But is stuck on identifying network and will no grant me internet access. There is also a new and strange "Unnamed Network" listed in my wireless networks with strong connectivity.
Not sure if this helps but when we set up the wireless router, there was a 3G and 5G network broadcasted by the router that's now gone and I just have my standard 1 wireless network and this "unnamed network".
Here are the windows troubleshoot details:
Network Diagnostics Publisher details
No issues detected
Detection details Expand
InformationalDiagnostics Information (Network Adapter)
Details about network adapter diagnosis:
Network adapter Wireless Network Connection driver information: (My network is "The 1849")
Description . . . . . . . . . . : ASUS PCE-N15 11n Wireless LAN PCI-E Card
Manufacturer . . . . . . . . . : ASUSTeK Computer Inc.
Provider . . . . . . . . . . . : Realtek Semiconductor Corp.
Version . . . . . . . . . . . : 2012.14.417.2014
Inf File Name . . . . . . . . . : C:\Windows\INF\oem16.inf
Inf File Date . . . . . . . . . : Thursday, May 01, 2014 1:59:28 AM
Section Name . . . . . . . . . : ASED8192Ce.ndi
Hardware ID . . . . . . . . . . : pci\ven_10ec&dev_8178&subsys_84b61043
Instance Status Flags . . . . . : 0x180200a
Device Manager Status Code . . : 0
IfType . . . . . . . . . . . . : 71
Physical Media Type . . . . . . : 9
InformationalDiagnostics Information (Wireless Connectivity)
Details about wireless connectivity diagnosis:
Information for connection being diagnosed
Interface GUID: e2f4bc57-482b-4d3c-b245-f5ad2aadebf6
Interface name: ASUS PCE-N15 11n Wireless LAN PCI-E Card
Interface type: Native WiFi
Connection incident diagnosed
Auto Configuration ID: 1
Connection ID: 2
Connection status summary
Connection started at: 2015-06-12 08:01:56-084
Profile match: Success
Pre-Association: Success
Security and Authentication: Success
List of visible access point(s): 5 item(s) total, 5 item(s) displayed
BSSID BSS Type PHY Signal(dB) Chnl/freq SSID
FA-8F-CA-75-D8-B8 Infra <unknown> -63 1 (Unnamed Network)
A4-2B-8C-BB-D3-13 Infra <unknown> -69 1 The1849
00-22-75-D2-6E-F0 Infra <unknown> -70 1 Teddy's Network
38-B1-DB-4E-1E-73 Infra <unknown> -72 11 msm
F8-35-DD-0B-14-58 Infra <unknown> -74 11 Speedy
Connection History
Information for Auto Configuration ID 1
List of visible networks: 5 item(s) total, 5 item(s) displayed
BSS Type PHY Security Signal(RSSI) Compatible SSID
Infra <unknown> No 64 Yes (Unnamed Network)
Infra <unknown> Yes 52 Yes The1849
Infra <unknown> Yes 50 Yes Teddy's Network
Infra <unknown> Yes 45 Yes msm
Infra <unknown> Yes 42 Yes Speedy
List of preferred networks: 1 item(s)
Profile: The1849
SSID: The1849
SSID length: 7
Connection mode: Infra
Security: Yes
Set by group policy: No
Connect even if network is not broadcasting: No
Connectable: No
Reason: 0x00028006
Information for Connection ID 2
Profile: The1849
SSID: The1849
SSID length: 7
Security: Yes
Pre-Association and Association
Connectivity settings provided by hardware manufacturer (IHV): No
Security settings provided by hardware manufacturer (IHV): No
Profile matches network requirements: Success
Pre-association status: Success
Association status: Success
Last AP: a4-2b-8c-bb-d3-13
Configured security type: WPA2-PSK
Configured encryption type: CCMP(AES)
802.1X protocol: No
Key exchange initiated: Yes
Unicast key received: Yes
Multicast key received: Yes
Number of security packets received: 0
Number of security packets sent: 0
Security attempt status: Success
Connectivity
Packet statistics
Ndis Rx: 233
Ndis Tx: 98
Unicast decrypt success: 0
Multicast decrypt success: 0
Unicast decrypt failure: 0
Multicast decrypt failure: 0
Rx success: 236
Rx failure: 0
Tx success: 0
Tx failure: 0
Tx retry: 0
Tx multiple retry: 0
Tx max lifetime exceeded: 0
Tx ACK failure: 0
Roaming history: 0 item(s)
Information for Connection ID 1
Connection started at: 2015-06-12 08:00:59-224
Profile: The1849
SSID: The1849
SSID length: 7
Security: Yes
802.1X protocol: No
Unicast key received: No
Multicast key received: No
Security attempt status: Fail 0x00048005
For complete information about this session see the wireless connectivity information event.
Helper Class: Auto Configuration
Initialize status: Success
Result of diagnosis: There may be problem
InformationalDiagnostics Information (Wireless Network Adapter)
Details about wireless network adapter diagnosis:
Helper Class: Native WiFi MSM
Profile: The1849
SSID: The1849
SSID length: 7
Security: Yes
Connect even if network is not broadcasting: Yes
InformationalNetwork Diagnostics Log
File Name: 3AD23C1D-64C6-4C6C-9B7F-B33AD7594733.Diagnose.Admin.0.etl
InformationalOther Networking Configuration and Logs
File Name: NetworkConfiguration.cab
Collection information
Computer Name: SEVERIAN
Windows Version: 6.1
Architecture: amd64
Time: Friday, June 12, 2015 8:17:34 AM
Publisher details Expand
Windows Network Diagnostics
Detects problems with network connectivity.
Package Version: 1.0
Publisher: Microsoft Windows
Thank you for your help and please let me know what other information I can provide!
No issues detected
Connection ID: 2
Connection History
Profile: The1849
SSID: The1849
SSID length: 7
Security: Yes
Connectable: No
Reason: 0x00028006
Profile: The1849
SSID: The1849
SSID length: 7
Security: Yes
802.1X protocol: No
Connectivity
Packet statistics
Ndis Rx: 233
Ndis Tx: 98
Rx success: 236
Rx failure: 0
Tx success: 0
Tx failure: 0
Tx retry: 0
Tx ACK failure: 0
Profile: The1849
SSID: The1849
SSID length: 7
Security: Yes
802.1X protocol: No
Profile: The1849
SSID: The1849
SSID length: 7
Security: Yes
Architecture: amd64
