Hello. Having read up on technology and played on a mid ranged system output to a 22 inch Dell IPS monitor, it is almost time to upgrade significantly. My goal is greater gaming immersion, everyday computer tasks and movies.
The games played will be fully modded Skyrim, modded Morrowind (with Overhaul package) , Elder Scrolls Online, and perhaps others.
I'm in the process of building a better PC. It will be , I think, sufficient to the task of running Nvidia 3dvision smoothly (a gtx 970, possibly SLI in the event of 3d vision, combined with an OC'ed (4ghz or so) pentium Anniversary edition dual core cpu.
Display option 1 :
24inch LG 24GM77, 144hz (3d ready) monitor for $300
an additional $100 is assumed to cover the Nvidia 3d glasses. A potential though uncertain(pending further feedback from the right honorable gentlefolk of the forums) necessity is an extra $320 for a second GPU to support smooth frames (50-60 fps PER eye).
I 've heard that the viewing angles are not great. But according to pro reviews, this LG is the best looking 3d capable monitor, with better colors than the competition.
cost - $620-750ish depending on GPU needs
Display option 2:
mid ranged 50 inch tv, probably an open box model.
Cost - $400
One benefit of the TV is that it will be good for movies, the monitor , not so much (if i want to lay around). Also, cheaper , since SLI wont be needed (if it is needed). On the other hand, I have heard rave review about Nvida 3d vision
Is 3d THAT worth it to go all in on a system? Skyrim? Morrowind? I could always return the items and try another option.
With the obvious caveat in mind, the subjectivity of beauty, I value your opinions, since getting into 3d is no small undertaking.
p.s. -
Display option 1 :
Display option 2:
Cost - $400
p.s. -
