pes 2017 installation problem
rahulsrm99
Commendable
Oct 19, 2016
when i was installing steam the installer said there is no internet connection even if there was wifi connection
Hope it help
First, make sure that the problem is not your PC and that your internet connection is working, try to restart your router or modem and connect to the game again.
Make sure that the game is not blocked by your firewall or any other antiviruses that you have installed on your PC
You should consider setting up a port forward for it to better your online gaming experience. There are quite a few reasons to set up a port forward for Pro Evolution Soccer 2016, such as: Fewer crashes when online, Easier to play with friends, Improved connection, Less lag, More stable, Enhanced overall online experience. If you need an open port on your router then you need to create a port forward. Open ports are used to allow a connection into your home network from the Internet. They are common in gaming, torrenting, and VOIP configurations. Use these guides to help you learn how to forward ports: https://portforward.com/router.htm
If none of these workarounds help you, you need to follow the tutorial at the end of the post and apply our patch to fix the server issues and connect to the game. Go below for more details!
http://gameserrors.com/fix-pes-2017-errors-server-issues-crashes-performance-issues/
