My Gateway FX530S, an older ATX, will not usually boot at all. Before I began to work on it, I tried it one last time (it had been in storage for 3 mo). Surprisingly, it went through all or a significant part of the boot-up before locking up. However, most of the time before the three months it simply gave me a black screen and I could hear the fans and hard drive running but nothing else. Prior to its complete failure, it shut off two or three times after making it into Windows and executing some programs. The final time it came on and actually got to Windows, it died almost immediately. After this, I got black screens and had to put in storage. I did check to see if the monitor was good. It was.
So I bought a PSU tester (led kind) and a dmm. I unplugged all the connections of the PSU and plugged a mobo tester to the 24 pin connection. Every led came on except -5v (which I came to understand is outdated and may not be present) and the PG led was definitely off. I confirmed by testing the PSU's mobo plug with a dmm. All the voltages indicated by the mobo tester were present and seemed within tolerance BUT still no 5v signal on the PG wire. What gives? How can this be?
