Question Phanteks 400 Front-facing fans won't start
Aug 3, 2020
Like the title says the Phanteks 400 front-facing fans on my build won't turn on. After replacing a DOA PSU I was able to boot up the system (Motherboard lights up/CPU fan starts turning), but I had no movement from the 3 stock fans running in the front. I tried connecting one of the unconnected SETA cables which resulted in nothing turning on. I also brought the case to a computer hardware store where they advised me to buy replacement fans and install those and then try again. Should I buy replacement fans? Or should I just buy a case with (hopefully) working front-facing fans? Any advice is appreciated.
Here are photos of the entire case/motherboard/connections: View: https://imgur.com/gallery/VWBJY5a
