phanteks enthoo evolv atx self contained cpu cooler
Zellris
18
Hi am planing to build a new computer and want to use the phanteks enthoo evolv atx as my case. My question is can I fit a 280mm radiator self contained liquid cooling like the Corsair H115i in the front intake with a push pull configuration ? Or do I have to use a 240 mm radiator ? I don't want to mount this in the top because it takes up to much space over the motherboard.
Up top, depending on your motherboard's heatsink height, yes you can!
The bracket is specifically designed with slotted mounts so as to enable the fitting and variable location of up to 280mm or 360mm radiators. Once attached, the drawer is simply slid back into place and secured with screws.
Furthermore it's offset so you can mount a radiator to the top without worrying about it conflicting with your motherboard.
But if you'd like to mount it in front, according to your manual(page 5) the case can support a maximum of a 280 at the front.
Might want to pas son...
Might want to pas son your proposed build specs in case something may be off...? Doesn't hurt to have some second opinions either.
Thanks for the quick and informative reply.
As for my specs this is what i have been looking at so far:
- ASUS ROG Maximus VIII Formula, S-1151
- Intel Core i7-6700K Skylake
- Corsair AX 1200i, 1200W PSU (I know this is probably a bit overkill 😉)
- Corsair Dominator DDR4 3400MHz 16GB
- Corsair Hydro Series H115i CPU cooler
- Phanteks Enthoo EVOLV ATX
- Corsair SSD Force Series LE 960GB 2.5''
- Havent picked out a graphics card yet but it is probably going to be a Nvidia GTX 1080
