Lucky_SLS :
Well, I can say they the lower level models like versa series from tt are utter crap. But the latest models are atleast somewhat decent. My friend has a view 31 build. Its not bad imo. At least not as bad as you put it. Considering that the view 71 is kinda like the flagship, surprised about the rant.
I have also seen the corsair spec 04, it's not any better than the view 31. Maybe ur expectations are just too high XD.
View 31 was the model I've worked the most,really great case for the asking price.It's easier to modd it.But reality stands, steel quality is really bad...Tempered side panels are fairly sensitive,and with a few open/close action they will be chipped at the edges.
The good part view 31: With a two holes on front at the top and little dremel action you can easily put a 420mm rad in front(also you need to cut out some plastic on front cover,its a bit tricky to release acrylic window from its frame but its worth it)
Also,custom PSU shroud is easy to install in it,and to make back PSU mounting option is no fuss at all(again dremel work,nothing hard).Front I/O panel also is easy to be manipulated into instaling better 3.0 USB or antivandal power button.
Also it is easy to remove and replace mobo tray,which is necessary if you re planning on installing thicker rad on top.
View 71: offers great specs for the price,but the main quality issue remains..oh those rivets
😀 ....Its poorly executed.But ,at the end I have dremeled out fixed screws without damaging the case,replaced USB cables and 3.0 ports with flat ones.installed custom psu cover,modded drop in radiator bracket to fit multiport radiators,also I elevated the drop in bracket a bit so I could install fans in push only config.you do have at the bottom in front a door for drain port,at the top ,you really can do a lot of tubing with no modding,but at back of the mobo you need to install some kind of cable management clips because there aren't any
😀 just 30mm empty space behind mobo tray..Hinges are great idea,but again poorly executed.
😀 Had to superglue that cylinder on the hinges
😀 Glass edges,well,I think I will be ordering custom made panels with better brushed edges.Frame on view 31 have ticker paint coating that view 71. My expectation are not too high,if they are going to sell something as high end,with all the tricks/ blows and whistles,than make sure to deliver it.It seems to me,that most tech companies take their customers for fools...(all of them for all the segments of PCs) xD
I think I can't go anymore detailed than this,but I will post some pictures of the good and bad and the ugly about the view 71.
