Phanteks Enthoo Pro front panel headers question.
92hatchattack
Commendable
Feb 12, 2017
92
Hey gang.
I'm hoping this is a nice simple question for one of you out there.
So, the Reset and Power front panel headers coming from my Phanteks Enthoo Pro case do not specify which pin of the connector is the ground. What is does have on the plastic is a little arrow or triangle pointing to one of the pins. I'm assuming its to either specify ground or signal pin, but I don't know which one.
Does anyone know?
The triangle is used for some odd reason instead of a + sign
But dont worry, if you connect it wrong you will not damage anything :)
So the side without the triangle would be the ground then? And yes. Still building. I'm doing it with my 12 year old son, and I only get about an hour with him a day on the weekdays so we are taking are time and slowly knocking away at it. We are both enjoying it, until he goes home and i freak out for hours about what wire goes where.... LOL
Thank you for the reply!
