Phanteks Enthoo Pro PWM Hub Issue
MartinEggman
26
Reassembling my PC components Into a new case I decided on buying the Enthoo Pro by Phanteks as I liked the design, all has gone smoothly up until this point of the two fans that shipped with this case are not running, they're plugged Into the hub already and the SATA 12v Power Input cable Is also connected to a SATA power connector. The case also comes with a 4 pin fan connector that goes from hub to the CPU FAN slot on the motherboard as the manual states, however this lead does not reach and now I'm at a dilemna. The manual also says you can use other slots such as: CPU_Fan2, CHA_Fan and OPT_Fan. I however don't see any of those slots on my motherboard.
Pictures: http://imgur.com/a/9Eatm
Manual: http://www.phanteks.com/assets/manuals/PH-PWHUB.pdf
Motherboard Is a Gigabyte GA-Z77-DS3H, and I was presuming I may have to buy an extension for the 4 pin I was just wondering If I'd missed anything.
They're all SYS_Fan connectors, the manual of the PWM Hub doesn't state them so I wasn't sure as It only says these: CPU_Fan2, CHA_Fan and OPT_Fan. Would the SYS_Fan connectors do the same thing?
SYS_Fan 2 was the only slot It would reach but luckily It's enough to make the PWM Hub kick In and get the fans that shipped with the case spinning. Can you control fans speeds with this hub or Is it done behind the scenes with voltages?
