Phanteks Evolv atx or Coolermaster mastercase maker 5
If the price is no matter for you, then pick up the Phanteks case since it has better cooling/cooler mounting options as opposed to the Coolermaster offering. Apparently getting a 2x120mm radiator at the top causes an issue with the end tanks.
I would like to stress though about your case selection, that it would be narrowed down with the components you're going to populate the chassis with. So to that extent, what are your intended internal specs going to be?
