Hi all!
Recently built in the phanteks evolv shift 2 and had some huge troubles with my 120mm aio (couldn't wrangle the tubes) so I ended up getting a Noctua NH-L12S in this configuration:
View: https://imgur.com/a/1Zv14I5
It works fine and silent with the case panel OFF, but when it's on I get this really annoying fan whine (I believe it's turbulence) any ideas on how I can mitigate this? I've been considering removing some of the supports from the panel to give the fan more breathing room.
Thank you so much for your time
