Phanteks Introduces the PH-F140SP and PH-F140XP Premium Fans
their stuff works well, especially their CPU heatsinks. but honestly they are a bit of a Noctua copycat, which is good because I guess if you're going to copy you might as well copy the best. if you want Noctua quality without the poop-brown colors, you buy from phantek
Ha! That's so true. If you want a noctua copycat that has better color choices, then phanteks seems like the best choice. I'd love to buy a noctua, but their color options are awful.
I bought a Noctua A15 a while ago to replace a Coolermaster 140mm
rear case fan. If these Phanteks fans had been available earlier, I would
have bought one of them instead since the CPU HS is a black Phanteks
PH-TC14PE with 3 white fans. The Noctua works very well, but the colour
is pretty grim.
I was going to say on the other hand that price is a factor aswell, but a
quick Google shows the PH-F140XP being around 15 UKP, which is quite
a lot less than the A15. Definitely a no-brainer IMO, asssuming these
new fans perform as claimed.
It's been a while since we've had a fan review. Tarun, how about a 120/140mm
fan round up?
Ian.
