Phanteks P350x Front Panel Connectors Routing (I'm confused0
nospecgamer
163
6
4,615
I'm planning on building a budget 1050 ti build which is fully listed out already. But, for the case which is the Phanteks P350x RGB, it comes with the USB 3.0 Connector, Audio, Power Switch, and a SATA Connector? I've been researching about the last cable on where that would go, according to the Manual it says, "Power Supply". But I can't shove a SATA Cable into the plug-in spots. What do I plug that cable in? A regular storage SATA cable to plug into the cable? I don't have the case yet soo, I don't know much about what it looks like. I remember seeing someone plugging in the P400s's SATA Front IO connector to another SATA but I don't know if that goes into the P350x too. I also don't know what the cable is for, the Power is given, Audio is give, USB is given, RGB is by some weird Front Panel attachment system, what is the extra cable for? I assume just by looking at pictures is that it's for the RGB to have power in general. Someone please help me out before I order the hardware, I need to know what it's for and where it goes. I'm new to Computers so, keep that in mind if this post is just a brain-fart.
It's probably to power the RGB lighting. The SATA connector is a male plug which will plug into a female SATA plug from the power supply (it'll be the same plug you use for the hard drives).
