phanteks p400s tempered glass and rear 120mm aio
difrio77
31
I recently ordered a phanteks eclipse p400s tempered glass in black with white interior and I also ordered a artic cooling liquid freezer 120 to mount on the back as exhaust. is this going to look stupid ? because the artic cooling liquid freezer 120mm is a really thick radiator and it comes with x2 fans for push pull so its comes to 99mm thick and also is this cooler going to cover the rgb lighting I have on the back of my asus z270 rog hero ix ? I been searching online everywhere for photos of a phanteks p400s with a rear mounted aio and cant find any
I did a little digging for you and found this:
By the looks of this picture it will fit, but it will cover the light on the upper left edge (where the light is) of the motherboard you mention. You will still have ambient glow from behind the radiator though.
You also have the light strip that is included with the case. You can connect that to your motherboard instead of the case and use it with aura too. This might offer more of a color change when using the program.
You could also just connect it to the font of the case. like this...
You could also just connect it to the font of the case. like this:
Might be useful to spend a minute looking around here:
pcpartpicker.com/builds/
the complete builds section is super helpful. Just search the brand or model of your case. Always saves the day.
