Phanteks PWM hub cpu_opt vs cpu_fan?
detroitwillfall
519
46
I originally had the cpu fan header cable provided by the phanteks hub just plugged into my 4-pin cha_fan header, but have since plugged it into the cpu_opt header.
my cpu cooler is plugged into its default cpu_fan header.
Is there a better way to do this?
All that matters is im able to adjust the fans in the bios correct?
Asus z170A/phanteks enthoo evolv atx TG/cryorig h7
detroitwillfall
519
46
i just used a cha fan header for the hub and it seem to be much quieter. it tried using cpu_opt for the hub and even with Q Control it was loud so i switched back and it seems fine.
Yeah its awesome, cant complain!
Similar threads
