Phanteks RGB Led strip makes a little noise, is it ok?
Alberto_x86
7
Hi All,
Hi All..
Two days ago I just installed a couple of RGB Led strips because there was nothing to improve my first pc build (I have a core i7 8700k mounted in an Asus Z370 E-Gaming, 16 Gb Ram, SSDs and I thought the next step it's installing some RGB strips).
And yesterday at midnight when it's completely in silence I realize that a little buzzy came from my pc, so I started to test what was happening until I turned off the rgb led strip and the buzzy disapeared. So I am concerned about if this is normal and I have nothing to be concerned. And if is there a way I can solve it?
Please let me know your comments, any comment will be appreciated.
Thanks!
If it bothers you, grab a refund, but I don't think its anything severe. Possibly coil whine (though I doubt that due to the simplicity of most led strips). It could also be some interference with another component and your leds, as I have heard of that happening.
