Phantom 410 Case Fan stopped working
andranos
23
Hey guys,
I'm not that knowledgeable with PC hardware so i need your help
I just realized that all 3 of my Phantom 410 Case Fans are not working
They were working fine yesterday so I'm a bit confused atm
The only thing I did yesterday was reseating my GPU so I might hit the case fan cable
Pictures of my PC here:
http://imgur.com/a/OJFF9
Cheers!
Simple test, unplug 1 fan and plug it, on the motherboard (right top corner). If it work, something is messed with the case cables, look for the molex (4 pin) coming from the case which power them up.
Yes it does work if i plugged it to the mobo. So is that correct that those 3 cables ended up at the direction i pointed in the pic above?
