Phantom 410 Water Cooling Loop Radiators/Pumps
jjesco5
59
Hey yalls, I am looking to put in a water cooling loop for my rig.
I am currently running
3570k @4.4Ghz with 1.18V
P8Z77-V LE PLUS
(in the process of buying a gtx 770, will add a second one later, I don't know if I should cool it or not)
vengeance 1600 ram 8gb
Hyper 212 EVO
OCZ modxstream 600w (will upgrade after gfx card is bought)
Phantom 410
840 pro
seagate 2tb
I want to push my chip farther as I enjoyed getting it to 4.4 but I want to get it to its max. I am also tired of the fan noises.
I was thinking of getting the XSPC Raystorm 750 RX240 kit but I am not sure if it will handle a gfx card or even fit in the case. I think it will on top of the case but I am not sure if the top will come back on evenly.
Alternatively are there better components to get than what is in the kit for a similar price?
Look this video. Maybe you get some ideas from it :)
Good luck with your build :) Hope this did help :)
My suggestion is get bigger rad. Or Two.
Id buy this pump or other varint of this pump/res combo.
http://www.frozencpu.com/products/21023/ex-pmp-252/EK_D5_X-RES_Top_140_w_D5_Vario_Pump_EK-D5_Vario_X-RES_140_incl_pump.html?tl=g30c107s152
So this pump. http://www.frozencpu.com/products/13147/ex-pmp-131/Alphacool_VPP655_Variable_Speed_Pump_w_RPM_Monitoring_-_Single_Edition.html?tl=g30c107s1802
+ top + res.
Then Alphacool NexXxoS rad. they have 120,140,180.240,280,,360(for 3*120mm fans and 2*180mm fan versions,420,480,540,560..
Then you just need cpu block and some tube and fittings. Maybe some water additives too. Then you are good to go.. :)
Here you will find all parts you need. Well maybe not all.. But loot other stres too :)
What video were you mentioning? I think you may have forgotten the link.
