Phantom 410 water cooling setup help
Galek105
29
I have an NZXT phantom 410 case and im running an fx-6300 and an r9 280 in it with a 550w power supply. I was wondering whether or not i could get a liquid CPU cooler with dual fans and take the stock top fan off on the top of the case to make room for a dual sized (2 fans) radiator or if i should just get a single sized radiator (1 fan). I am also wondering if I should get a larger PSU for a liquid cooler? please help me
Here are the listed features for your case off of the NZXT site...you should not need a bigger PSU for just adding the water cooler.
Features
• Clearance for top 240mm dual radiator for water cooling solutions
• Adjustable interior pivot 120mm/140mm fan slot for directional air flow
• Removable HDD cage to allow more room for extended video cards
• Innovative right mounted HDD rails for easy hard drive replacement
• Single 120mm/140mm side fan with acrylic window for interior viewing and cooling
• Front Internal 2x USB 3.0 headers, 2x USB 2.0, audio and microphone input
• 30W 3-step fan control for setting up your system for silence or performance
• Wire management support up to 25mm space for easy cable...
Features
• Wire management support up to 25mm space for easy cable management
• Screw-less 5.25” and HDD trays that secures 2.5” SSD
• Cooling capability of up to eight fans (2x 120mm and 1x 140mm LED fan included)
Do you think I could put a kraken x41 in the case and mount the rad at the top?
That is pretty expensive for a 140mm cooler, but it should fit as long as there is nothing within 2.5" of where you plan to mount it. It has a over thick radiator 36mm and the fan is 25mm, or 2.4" inches thick all together.
