Question Phantom Spirit 120 fan connectors
mikejs78
39
Just installed the phantom 120 spirit in my new build. The Spirit comes with a Y cable for the two fans, however my MB (Asus ROG Strix x670e-f) looks like it has 2 CPU fan ports unless I'm reading it wrong. I assume it's better to use the two ports rather than the Y cable? Just wanted to confirm that with the experts here.
Also, does it matter which fan goes in which port?
without any connection to the CPU_FAN header the system will probably not boot.
CPU_OPT usually follows the same settings as CPU_FAN.
just there for easier setup when using a dual fan cooler.
whether you use a splitter and both connect to the single CPU_FAN header,
or just connect those 2 individually to the CPU_FAN & CPU_OPT headers,
it shouldn't really make any difference.
Reactions: Why_Me and mikejs78
