I have purchased a GA-X48-DS5 and it is not working properly.
No CD will boot correctly and no programs will run without hanging.
I have tried a windows xp CD and it gives a page fault when it boots and the CD does work fine on my other PC. I have tried utility CD's and usually it will not show any menu and when it does get that far no program will successfully load.
When it boots all the Phase LEDs on the motherboard are lit and I can go into the Bios and check everything is correct and that the cpu temperature is okay and it is fine, 25/26C using the retail cpu heatsink. When it leaves the Bios and begins the boot process it gets as far as Verifying DMI pool data and then all the Phase LEDs go out which does not seem correct. Surely there should always be at least one or two lit LEDs?
I have tried a very mininum build of just 1 stick of Ram and 1 IDE DVD-Rom set to master and I cannot get anything to run fully without errors or hanging. Memtest run from a floppy hung at test 4 which just shows how unstable the CPU is. I suspect that the power delivery to the CPU is not functioning correctly due to a defective DES system which is resulting in severe system instability when power is required.
What I need to know before RMAing the motherboard is what sequence the Phase LEDs go through when booting and running programs. Also do the LEDs ever go out completely? This would give me important information which would back up my case for a RMA and hopefully speed it up.
So if you own one of the motherboards listed below or any others which have Phase LEDs that I missed, then please have a look to see if yours are working and post a reply with the results.
GA-X48-DS4
GA-X48-DS5
GA-X48-DQ6
GA-X48T-DQ6
GA-EX38-DS4
GA-EX38-DS5
GA-EX38-DQ6
GA-EX38T-DQ6
GA-EP35-DS3
GA-EP35-DS3L
GA-EP35C-DS3R
GA-EP35-DS3P
GA-EP35-DS3R
GA-EP35-DS4
GA-EP31-DS3L
GA-EG31MF-S2
GA-EG31M-S2
System:
Gigabyte GA-X48-DS5
Q9450 CPU
4GB (2x2GB) OCZ Reaper HPC PC2-8500
Tagan TG480-U01 PSU
Gigabyte 512MB HD3850 PCI-e Graphics card
GA-X48-DS4
GA-X48-DS5
GA-X48-DQ6
GA-X48T-DQ6
GA-EX38-DS4
GA-EX38-DS5
GA-EX38-DQ6
GA-EX38T-DQ6
GA-EP35-DS3
GA-EP35-DS3L
GA-EP35C-DS3R
GA-EP35-DS3P
GA-EP35-DS3R
GA-EP35-DS4
GA-EP31-DS3L
GA-EG31MF-S2
GA-EG31M-S2
System:
Gigabyte GA-X48-DS5
Q9450 CPU
Tagan TG480-U01 PSU
