Hi there,
I just recently clocked my Phenom II X6 1090t from 3.2 Ghz to 3.8 Ghz using BIOS. During the clocking procedure I upped the voltage a few times because I was not stable on 3.7GHz at the standard 1.375 v. And whenever I upped the frequency to 3.8, it would not boot into Windows and instead Blue screen. So then I took the voltage up to 1.425 v and then at 3.8 GHz the cpu ran fine. It booted faster and all programs were operating normally. I have Core Temp running the whole time to see if my CPU was actually producing the desired frequency. It was, but my primary concern was the CPU's temperature during idle. Before clock, at 3.2, I was idling at around 28-30°C and now I am at 38-42°C (during idle). Now I am wondering if I put too much voltage to the CPU? Just for info, I am using the Arctic Freezer Rev.2 CPU cooler and I have two fans above the CPU pushing the air out of the Zalman z11 plus' top fins.
Thanks in advance!
Thanks in advance!
