C charanrajkumar9 Sep 16, 2018 1 0 10 Sep 16, 2018 #1 Everytime I power off and power on, my sound bar goes to factory default and I am forced to set it as per my liking. How do I preserve/save the settings permanently. TIA.
Solution Phillip Corcoran Sep 17, 2018 Manual changes to sound settings should be saved automatically from what I can gather reading the manual. Reversion to factory settings should only occur when Volume -, BASS -, and TREBLE are pressed in sequence within three seconds. http://download.p4c.philips.com/files/h/htl2163b_12/htl2163b_12_dfu_aen.pdf You may want to try updating the unit's software (page 11 of the manual).
Phillip Corcoran Titan Moderator Sep 7, 2013 26,050 889 120,140 Sep 17, 2018 Solution #2 Manual changes to sound settings should be saved automatically from what I can gather reading the manual. Reversion to factory settings should only occur when Volume -, BASS -, and TREBLE are pressed in sequence within three seconds. http://download.p4c.philips.com/files/h/htl2163b_12/htl2163b_12_dfu_aen.pdf You may want to try updating the unit's software (page 11 of the manual). Upvote 0 Downvote Solution
