Hi All
I just bought a monitor Philips 223V5LSB. I took it because in the description it said there was a DVI port, I am relying on the onboard graphics and my motherboard has only digital output (hdmi and DVI-D).
When I opened the box I found out the monitor had only a VESA cable, I went to look for a DVI cable, but nowhere I could find a cable with both plugs DVI-D, eventually I bought a cable HDMI to DVI-D.
I plugged the cable into the monitor and switched on. The monitor said "No video input" and went to sleep mode.
I tried to search for information in the manuals, but nowhere it says how to switch from analog to digital signal, I assume it should be detected automatically by the monitor, but it doesn't work.
The on screen menu doesn't work either, if I switch it on the first menu that appears is the language choice, but when I press the OK button it goes to sleep mode. I suspect that it need a video signal as well to setup things like brightness and color.
At this point I got no idea about what to try next.
Thanks in advance for any help,
